Skip to main content
Version: 11 Nov 2025
Audio Input
This section provides examples of how to use Magic Leap's APIs to record audio.
caution
This features requires the RecordAudio permission to be requested at runtime and enabled in your project's Manifest Settings (Edit > Project Settings > Magic Leap > Manifest Settings).
Raw Audio Samples​
This example shows how to obtain the raw audio buffer samples from the microphone as soon as they are received
using System;
public class ML2BufferClip : MLAudioInput.BufferClip
public ML2BufferClip(MLAudioInput.MicCaptureType captureType, int lengthSec, int frequency) : this(captureType, (uint)lengthSec, (uint)frequency, (uint)MLAudioInput.GetChannels(captureType)) { }
public ML2BufferClip(MLAudioInput.MicCaptureType captureType, uint samplesLengthInSeconds, uint sampleRate, uint channels)
: base(captureType, samplesLengthInSeconds, sampleRate, channels) { }
public event Action<float[]> OnReceiveSampleCallback;
protected override void OnReceiveSamples(float[] samples)
base.OnReceiveSamples(samples);
if (OnReceiveSampleCallback != null)
OnReceiveSampleCallback(samples);
Simple Audio Input Example​
This example demonstrates how to record audio on Magic Leap 2 and play it back instantly.
public class AudioEventExample : MonoBehaviour
[SerializeField, Tooltip("The audio source that should replay the captured audio.")]
private AudioSource _playbackAudioSource = null;
private MLAudioInput.StreamingClip mlAudioStreamingClip;
private MLAudioInput.BufferClip mlAudioBufferClip;
void Awake()
if (_playbackAudioSource == null)
Debug.LogError("PlaybackAudioSource is not set, adding component to " + gameObject.name);
_playbackAudioSource = gameObject.AddComponent<AudioSource>();
MLPermissions.RequestPermission(MLPermission.RecordAudio, permissionCallbacks);
void OnDestroy()
StopCapture();
private void StartMicrophone()
_playbackAudioSource.Stop();
var captureType = MLAudioInput.MicCaptureType.VoiceCapture;
mlAudioStreamingClip = new MLAudioInput.StreamingClip(MLAudioInput.MicCaptureType.VoiceCapture, 3, MLAudioInput.GetSampleRate(captureType));
_playbackAudioSource.pitch = 1;
_playbackAudioSource.clip = mlAudioStreamingClip.UnityAudioClip;
_playbackAudioSource.loop = true;
_playbackAudioSource.Play();
private void StopCapture()
mlAudioStreamingClip?.Dispose();
mlAudioStreamingClip = null;
mlAudioBufferClip?.Dispose();
mlAudioBufferClip = null;
// Stop audio playback source and reset settings.
_playbackAudioSource.time = 0;
_playbackAudioSource.loop = false;
_playbackAudioSource.clip = null;
StartMicrophone();
Debug.Log($"Succeeded in requesting {permission}.");
Delayed Audio Playback​
This example demonstrates how to record audio on Magic Leap 2 when a certain volume threshold is reached, and play back the recording at a lower pitch than it was captured.
using System.Collections;
using System.Linq;
[Header("Delayed Playback")]
[SerializeField, Range(1, 2), Tooltip("The pitch used for delayed audio playback.")]
private float _pitch = 1.5f;
private bool isAudioDetected = false;
private float audioLastDetectionTime = 0;
private float audioDetectionStart = 0;
private readonly float[] detectionAudioSamples = new float[128];
private const int AUDIO_CLIP_LENGTH_SECONDS = 60;
private const float AUDIO_SENSITVITY = 0.02f;
private const float AUDIO_CLIP_TIMEOUT_SECONDS = 2;
void Awake()
void OnDestroy()
StopCapture();
mlAudioBufferClip = new MLAudioInput.BufferClip(MLAudioInput.MicCaptureType.VoiceCapture, AUDIO_CLIP_LENGTH_SECONDS, MLAudioInput.GetSampleRate(captureType));
_playbackAudioSource.pitch = _pitch;
private void Update(){
DetectAudio();
private void DetectAudio()
// Analyze the input spectrum data, to determine when someone is speaking.
float maxAudioSample = 0f;
while (true)
int readSampleCount = mlAudioBufferClip.GetData(detectionAudioSamples, detectionAudioPosition, out int nextPosition);
if (readSampleCount == 0)
break;
detectionAudioPosition = nextPosition;
maxAudioSample = detectionAudioSamples.Take(readSampleCount).Append(maxAudioSample).Max();
//Audio samples can also be read directly instead of via callback using the mlAudioBufferClip.GetData()
maxAudioSample = samples.Append(maxAudioSample).Max();
if (maxAudioSample > AUDIO_SENSITVITY)
audioLastDetectionTime = Time.time;
if (isAudioDetected == false)
isAudioDetected = true;
audioDetectionStart = Time.time;
else if (isAudioDetected && (Time.time > audioLastDetectionTime + AUDIO_CLIP_TIMEOUT_SECONDS))
var audioDetectionDuration = Time.time - audioDetectionStart;
_playbackAudioSource.clip = mlAudioBufferClip.FlushToClip();
_playbackAudioSource.time = _playbackAudioSource.clip.length - audioDetectionDuration;
// Reset and allow for new captured speech.
StartMicrophone();
Read Audio Buffer Data
You can read the audio buffer data directly using the MLAudioInput.BufferClip.GetData() function. Here is a simple script that shows how to read buffer data. It doesn't play the audio back, but you can use it as a reference on how to obtain Audio Samples using the GetData function.
using System.Linq;
//Magic Leap Audio Capture Settings
private MLAudioInput.MicCaptureType captureType = MLAudioInput.MicCaptureType.VoiceCapture;
//Used to read the buffer data directly
private int detectionAudioPosition = 0;
//Magic Leap permissions
//True if permissions were granted and the microphone is initialized
private bool _microphoneStarted = false;
void Awake()
void OnDestroy()
StopCapture();
StartMicrophone();
_microphoneStarted = true;
if (_microphoneStarted)
DetectAudio();
while (true)
break;
